Liked 472 Times in 115 Posts
For the new FGT project Dart sport, for max weight reduction for a head ups run etc.
No alternator of course, two battery slots in trunk any one ever run a single braile AGM 17 pounder? It will still get down to the weight class desired with a single tried and true optima redtop AGM. But in a head ups run, you need everything you can get. I know they are used frequently in stockers, with altenators of course....... Maybe a Indy qualifier has done this? Thanks Eric
Eric Merryfield 1883 STK |
Liked 536 Times in 121 Posts
Eric, I called FAST a while back with the same question. There response was if I remember correctly was 10-10.5v. It was way lower than I expected. I tried to locate amperage draws for the fuel pump, ignition, and water pump. Thought that might be useful too. Mike McMahan 2543 H/SA
