Old 12-05-2007, 12:42 PM   #1
rickster
Default Stick Cars:gear Swap Results
i would like to see the results of rear gear swaps
60',et,mph
stick cars only please because i'm running a clutch car
thanx
rickster is offline   Reply With Quote
Old 12-06-2007, 12:56 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: Stick Cars:gear Swap Results
I can say this; over-gearing can have as much negative impact as under-gearing.
Your question is to broad and vague for anybody to provide help.
Jeff Lee 7494 D/S '70 AMX
Old 12-07-2007, 09:27 AM   #3
rickster
what i'm looking for is an example of a gear swap,from not enough to optimum
which would help starting line leverage,and keep the motor in the powerband thru the lights
how does it effect 60',et,mph??
come on guys [4.88 to 5.13] [5.13. to 5.38] or better yet [4.88 to 5.38]
each car will react different to these changes,but i'm just looking for trends
thanx
Old 12-07-2007, 10:58 AM   #4
Jeff Lee
Jeff Lee's Avatar
As the engine specs changed over the years (cam primarily), I saw improvements going from 5.13 to 4.88 in D/S. I had the 4.88's in when I converted the engine (just the engine) to SS/H. I went faster when I later placed the 5.13's back in the car (I only run a 29.5" slick). I'm now placing 5.38's in the car but am going to a slightly larger tire. You just need to do the math on gears to the RPM your engine works best at. Heck, there are 455 pontiac's that are fast, really fast and only run a 3.73 gear in D/SA. I know turbo cars that have 3.90 gears. So, sorry, it all depends!
A general rule of thumb on a stick is 1st gear x rear gear should be around 15.00. Try that and see if that helps. But do the math!
Old 12-07-2007, 10:12 PM   #5
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
this all depends on hp vs torque the bigger cubic inch engines can run a higher gear ,even though the cam shaft may have a crazey duration ,smaller engines need a lower gear to perform,this is not news to most but,stockers try to run out the end on rpm and some times big cubic inch engines suffer,i put it like this ,i had a 455 buick, i could throw the brick on the gas pedal and it wouldnt rev past 5000 rpm free wheel no matter how long it sat there,it wouldnt blow up ,it would 60 ft like crazy but you where i high gear way before the 1/8 and you where hanging ,each application is different good luck gmonde
Old 12-09-2007, 01:32 AM   #6
Adger Smith
Liked 880 Times in 311 Posts
Rear gear & tire size for finish line RPM & MPH. Transmission gear ratios for leave & split times.
Adger Smith (Former SS)
Old 12-15-2007, 07:16 PM   #7
acme383
the best thing i did this past year, was go from a 4.88 to a 5.13. sixty foots dropped and so did et. my car has a 98" rollout on the tire with a 500cid stroker leaving at 6800-7400rpm.
acme383 is offline   Reply With Quote
