Old 12-02-2007, 11:42 AM   #1
will prater
Liked 7 Times in 4 Posts
Default rear floor material question
I need some clarification of the material used between the rear frame rails for SS car. When moving and replacing the rear frame rails does the original material need to be sectioned and reinstalled to be legal for SS. In this case it is a '68 Dart which would be the big ugly deep spare tire well.
thanks
will prater is offline   Reply With Quote
Old 12-02-2007, 11:54 AM   #2
Stewart Way
Liked 70 Times in 22 Posts
Default Re: rear floor material question
As it says in the rulebook , between the framerails you must keep the stock floorboard in the stock location. The spare tire well must stay.
Good luck with the Dart. I'm doing another Cuda right now. Can't decide if I'm going to move the stock rails or use round tubing.
What class you building for and what rear suspension will you run?
Old 12-02-2007, 02:55 PM   #3
will prater
Stewart, I am looking at JA. I am going to use the caltrac split mono that is on the car. We are going to either move the rails in or replace them. I am using a 12x 30 now but it is a tight fit. I think that will be enough tire for J but if not we want the ability to go with a 13x31.
Old 12-02-2007, 05:47 PM   #4
Stewart Way
Will
Sounds like we are looking at close to the same package. I'm going to run GT/EA with the 383 in a 68 Cuda. I am still kicking around the Caltracs. If I use Caltracs I will use the stock rails but likely moved in just incase I need more room. Car goes to the blaster this week, then I'll have to decide Caltrac or 4 link. The rear already has 4 link at about 24" spacing so I could still use it with the leafs under the rails at about 28-30" and still hang front 4 link mounts in the car. The Cuda has a little over 15" from rail to the inside of the quarter panel. Guess, like you, I would be limited to 12" without moving the rails.
Give me a number wher I can reach you. Kick some things around.
Stewart
Old 12-02-2007, 06:34 PM   #5
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
FWIW,I use a 15x12 wheel,6.5" b/s with either a 13x31 or 12.2x31.25 Phoenix and stock frame rails in the OE location.Car is 1971 Demon.I also ran the same combo on a 1969 'Cuda.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 12-02-2007, 08:04 PM   #6
Bill Moulding
Will
I went thru this in 02 with my Camaro. Had it filled with flat metal of the same guage and was told no way. Unfortunately I had discarded all the metal from the original car so I had to buy another one just to get the section from the back to fill in between the frame rails. Would have been a lot easier to do when I was building the car than it was to fill it in afterwards. Good question and good advice from Stewart.
Bill
Bill Moulding is offline   Reply With Quote
Old 12-02-2007, 08:50 PM   #7
will prater
Chris- thanks for the info. It may help Stewart. The Dart must be slightly smaller. I would like to use the 12.2 x31.25w if I could. With the rails moved or replaced I can.
Bill- I had already cut out the tire well and was going to sell it to someone needing it for restoration. After re-reading my old rule book I noticed the requirement. Luckily it was still in the shop. I was hoping the rule might have changed in the past year.
Stewart- you can catch me Sunday and Monday after 9pm Central at 417-359-8309
Thanks
Old 12-07-2007, 10:05 AM   #8
Stewart Way
Will
Give me another time when I can reach you. Got tied up on a Home project, sorry.
Stewart
Old 12-07-2007, 10:45 PM   #9
will prater
Stewart, should be home all day Saturday except evening and all day Sunday.
