Old 01-23-2022, 05:34 PM   #1
steven reynolds
Liked 13 Times in 11 Posts
Default O2 sensors
I have a Holley dominator engine management system, I'm needing both O2 sensors, Is anything compatible that is less $$ than the Holley stuff, I about choked when quoted $600 for the pair. Please post, text or call with info. 936-Three 3 Four 588one.
thanks
Steve
steven reynolds is offline   Reply With Quote
Old 01-23-2022, 05:45 PM   #2
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Default Re: O2 sensors
thanks
Steve
Holley installs a resistor in the circuit of the 02. Installing a non modified unit will damage your Dominator.
Jeff Niceswanger 3740 SS
Old 01-23-2022, 09:20 PM   #3
Rob Petrie E395
Liked 216 Times in 77 Posts
There is a sensor for Honda’s that will “work”. But your readings may be off by .5-2.0 depending on the resistor in them. There is a lot more to it than that. But that’s the short version.
Old 01-24-2022, 10:19 AM   #4
Marty Buth
Liked 232 Times in 39 Posts
I would buy the Holley NTK O2 sensor. Lasts longer and worth the money.
Marty Buth 3657 STK
Marty Buth is offline   Reply With Quote
Old 01-24-2022, 10:55 PM   #5
GUMP
Liked 2,354 Times in 554 Posts
Run the Holley NTK sensors. They are as important as any other component you buy. As with many components, a compromise could have disastrous consequences.
Daren Poole-Adams
NHRA Stock/SS 2007
GUMP is online now   Reply With Quote
