Old 01-02-2022, 02:33 PM   #1
Rory Christianson
Liked 9 Times in 6 Posts
Default Manual Steering box 1st gen Camaro
Was wondering if I could get a recommendation on a manual steering box for a first gen camaro , I see flaming river makes one , a light one I think based off a Vega box with a pitman arm , think you have to use a flaming river joint to connect, seems a little pricey when all said and done. Any other suggestions ?
Thx
Rory Christianson is offline   Reply With Quote
Old 01-04-2022, 06:11 PM   #2
Tom O
Liked 151 Times in 36 Posts
Default Re: Manual Steering box 1st gen Camaro
Borgeson makes a stock replacement box i believe 350 400 $$ on Summitt.
Tom O is offline   Reply With Quote
Old 01-05-2022, 01:04 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
Several years ago I got this from Larry Woodfin
, you have several choices.
* S-10 manual box [with the S-10 box in most cases it is a direct replacement. Input spline & pitman spline same as OE. It will have a four bolt top]
* manual GM box from 70's cars [this is also a direct fit in some cases. GM produced several spline counts so it takes some comparing to find the exact match. This is a three bolt top. This box is about one pound lighter than the S-10 box and overall slightly smaller.
* Vega box [this box is smaller and lighter than both the above, however, it requires a custom/special pitman arm. Ed Quay, Flaming River, and maybe others furnish the special arm.
Of the three, I would look for the 70's box.
Larry Woodfin, GT Super 10
Adger Smith (Former SS)
Old 01-05-2022, 11:32 AM   #4
SST159
Liked 20 Times in 16 Posts
I have one out of my 70 Z28 if interested.
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
