Old 12-24-2021, 08:42 AM   #1
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Default Radiator?
I'm looking at an aluminum single core with plastic tanks. Anyone have any experiences to share? Post here or PM. Thanks!
Joe Marcinowski 3377 STK
Joe Marcinowski is offline   Reply With Quote
Old 12-24-2021, 10:33 AM   #2
SSDiv6
Default Re: Radiator?
My opinion is that is they are good for an OEM application, they should work on a drag car.
Old 12-24-2021, 11:54 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 2,005 Times in 602 Posts
Single core is fine. Mine has aluminum tanks
Mike Pearson 2485 SS
Old 12-24-2021, 01:47 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Aluminum tank radiators are a much better choice . Structurally stronger ,
[important for wheelstand cars] and safer ,the tanks cant blow off due to a blown head gasket .
I use a lot of Champion radiators , they have a good selection of direct fit radiators for most applications . and their prices are reasonable .
www.championradiators.com
Old 12-24-2021, 02:05 PM   #5
e vassar
Liked 281 Times in 110 Posts
Smile Re: Radiator?
Last one I bought was from Speedway. All aluminum price was very reasonable.
Old 12-30-2021, 08:52 AM   #6
Liked 11,032 Times in 2,267 Posts
1986 C10 Chevy 4.3 V 6 truck came with plastic ends on a cross flow single core aluminum radiator. Very lite and last time I bought one not to bad of price.
Old 12-31-2021, 02:21 PM   #7
Eman
Liked 133 Times in 76 Posts
Been using a stock replacement aluminum with plastic tanks on my 3rd gen Camaro for over 20 years. Came from Advance with a lifetime warranty. I changed it out once for the crappy petcock leaking from winter drain and refills. I JB'd the petcock on the new one and put a drain in the lower hose.
Old 01-05-2022, 12:31 PM   #8
SBillinson
Liked 183 Times in 48 Posts
I put a $110 single-core radiator with plastic tanks in my modified car because it was the lightest one I could find. I have put about 50 passes on the car running between 145-147 MPH and the radiator has held up fine. I've slammed the front end several times from violent wheelstands too.
I have a fitted aluminum fan shroud which may provide some rigidity but it attaches between the tanks. It's definitely not holding the radiator together.
SS/BS 1921
SBillinson is offline   Reply With Quote
