12-19-2021, 07:42 PM | #1 |
Liked 2 Times in 2 Posts
396+060 375hp stock elim engine
396/375hp all new never ran short block early 2 bolt filled block .300 thick cyl walls,light cast stoked 013 crank/ h beam rods, cp+060 pistons/ mm total seal rings/ ATI balancer/ #842 GM aluminum heads freshened./ #3163 intake/ .7/16 smith bros pushrods/ comp pro magnum steel rockers/ Trend solid edm hole tool steel lifter/D Elgin cam/corvette oil pan & windage tray +scraper / complete engine minus carb $7500 ( contact} Doug Holder 909 632-8325 SOLD thanks CLASSRACER
Last edited by dahkahuna; 02-24-2022 at 10:51 PM. Reason: selling as assembled engine complete less carb |
12-19-2021, 08:52 PM | #2 |
Liked 230 Times in 80 Posts
Re: 396+060 375hp stock elim engine and Parts
Hello Doug… Please check your PM. Thank you…MB.
02-08-2022, 05:26 PM | #3 |
Could you give me a call. Thanks Steve 217-473-1913.
