Old 11-30-2021, 03:39 PM   #1
Lyn Smith
Liked 1,002 Times in 203 Posts
Default Replay tach box
I know I have seen this device in one of the performance parts catalogs but cannot find it now. It is a electronic box you can wire into your tach that will make it a replay tach. Anyone familiar with this item, and who has them? Tried the tech people at Jegs, and Summit with no success. Thanks Lyn
Lyn Smith is online now   Reply With Quote
Old 11-30-2021, 06:48 PM   #2
HR3128
Liked 54 Times in 8 Posts
Default Re: Replay tach box
https://www.autometer.com/dpss-controller-level-1.html
I had this one ordered but they were out of stock with no idea of when they could deliver.
They are listed with different software levels that have different features.
HR3128 is offline   Reply With Quote
Old 11-30-2021, 09:58 PM   #3
Lyn Smith
The unit I was looking for was less than $50. and it just replayed the tach on the last run. It did not have any timers. Thanks for the info though.
Old 11-30-2021, 10:30 PM   #4
Rory McNeil
Lynn, I know I had an old Autometer playback module that piggybacks a conventional Tach to make it playback . Not sure if it came with me when I moved across Canada, but I will take a look in the garage tomorrow.
NHRA 6390 STK
M/S 85 Mustang
Old 12-01-2021, 03:27 PM   #5
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Sounds like an Autometer 9150 playbox box. Black box with 4 small buttons.It's unavailable but I saw it at north of $200. It has been replaced by Autometer 5312 Digital Shift Light Controller L1. Does the same as what you are looking for at $139.
You could do tach/shift/playback in one unit with a Level 3 Digital Shift Light at $250.
Good luck finding anything that works for anything at a $50 price point.
Dale Shearon
68 Mustang 6394
Old 12-02-2021, 10:16 PM   #6
Rory McNeil
Lyn, I did dig out my Autometer playback box, as mentioned, it has part number 9150, when I googled that number, it showed up on Summit Racings site, at $269. , but not available. No idea about a $50.00 item that would be like that.
NHRA 6390 STK
M/S 85 Mustang
Old 12-28-2021, 01:07 PM   #7
Lyn Smith
Finally found a older Summit catalog that had the Tach recall kit that I was looking for part number sum-800100-1 for $37.97. Will post a picture when I get a chance.
Old 12-28-2021, 03:08 PM   #8
FED 387
Liked 336 Times in 183 Posts
lyn ---just googled that number on the summit website says they have several in stock at the$37 price---Dick
Old 12-28-2021, 10:04 PM   #9
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Cool Re: Replay tach box
From what I just saw on the summit site it said it only recalls peak rpm and does not record a whole run. Wish it would have worked cause our autometer ultimate tach only records for 20 seconds. If you or the other guy takes his time staging it times out about 1200 ft mark.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 12-29-2021, 12:14 PM   #10
garyc
Liked 51 Times in 30 Posts
I had mine wired to brake lite switch, timer started when i left line
garyc is offline   Reply With Quote
