Old 10-07-2021, 08:07 AM   #1
Weekend Racer
Default coolant passage
On sbc chevy heads casting 441 ,Before angle milling heads ,do the spark plug coolant passage be plugged with epoxy .What your thoughts?
Weekend Racer is offline   Reply With Quote
Old 10-07-2021, 09:53 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 317 Times in 108 Posts
Default Re: coolant passage
If plugging those holes thread them and plug with bolts and loc tite or taper plugs...
Old 10-13-2021, 06:41 PM   #3
Tom Broome
Liked 88 Times in 43 Posts
This is the right way to do the job.
If you're unsure where to get the plugs and corresponding taps, check Goodson: https://goodson.com/products/crack-repair-plugs
Tom Broome is offline   Reply With Quote
