Liked 238 Times in 93 Posts
G.M. 05-10 Added replacement throttle body
seems a little vauge |
Liked 693 Times in 269 Posts
Vague?.
Right out of the 2010 Chevy NHRA blueprint specs. Holley Sniper 90 mm (3.545”) Throttle Body accepted High lighted in yellow
Adger Smith (Former SS) |
So any car or truck mfd by GM from 2005 to 2010 can use the Holley T.B.?
Liked 609 Times in 180 Posts
If it uses a 90 mm TB.
And is listed in the specs
Looks like the Holley is an approved replacement part/throttle body
Adger Smith (Former SS) Last edited by Adger Smith; 09-24-2021 at 01:54 AM. Reason: add |
This is most likely so they can run a cable driven throttle body and not a drive by wire.
Ross Gregory 5133 Stock,Super Stock 53 Top Dragster |
Liked 726 Times in 177 Posts
No. Only those engines where the replacement TB is allowed. It is a replacement for the OEM Bosch 12570790 TB in 2005-08 and the OEM Bosch 12605109 TB in 2010. The Holley part number is 860008-1.
