Old 09-20-2021, 01:37 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Power Brakes and Vacuum
Noticed that changing to the Stocker Cam from Pure Stocker.
Ran into two issues
Cannot hold the Converter as much on Launch.
Use to hold as much as 3200rpm.
Now barely launch above 2500rpm
The Line Lock will not hold the car during Burn Out.
Have to power brake to get the tires spinning.
Shut down after a run is no problem.
Is there a good solution to get more Vacuum Boost for the Power Brakes?
