Good Evening,I hope this is in the right place.I'm building a replica Pro Stock Truck,I found a set of Centerline Warrior spindle mount wheels for a strange strut, minus bearings and seals.I was told both bearings and seals were 1969 camaro pieces's. the bearings are correct but the seals are to small ,inner diameter is correct, out side diameter is to small . Any and all help will be appreciated. Thank You Robin Rogerson robin_rogerson@yahoo.com or 863-287-5888 Thanks Again
