Old 09-02-2021, 05:47 PM   #1
scott smith
Liked 13 Times in 3 Posts
Default roll bar
can the roll bar /cage go through the firewall and extend into frnt suspension , strut tower area in stock eliminator ? I did not think this was legal in stock , but was at a div. 1 race and saw this on a couple cars .
scott smith is offline   Reply With Quote
Old 09-02-2021, 05:55 PM   #2
Frank Castros
Liked 2,610 Times in 948 Posts
Default Re: roll bar
With what Stock Eliminator has become I'm all good with this, just put the damn battery in the trunk!
Old 09-02-2021, 06:34 PM   #3
GTX JOHN
Liked 2,425 Times in 687 Posts
Yep
There was a rule change a few years ago.
John Irving
741 Stock
741 Super Stock
Old 09-03-2021, 08:44 AM   #4
garyc
Liked 51 Times in 30 Posts
2021 rule book "front braces may not extend in front of firewall"
garyc is offline   Reply With Quote
Old 09-03-2021, 10:20 AM   #5
Charles Stewart
Liked 753 Times in 213 Posts
Just go to STOCK rules, section 11A, on page 10 in the FIREWALL section and you will have the specs/info/answer to your question regarding the front tubes.
Keep on,
Charles Stewart
Charles Stewart is offline   Reply With Quote
Old 09-03-2021, 12:43 PM   #6
SSDiv6
Liked 1,538 Times in 575 Posts
Not applicable if you have a roll cage.
Stock Cars Section 11A, page 10 and page 11
BODY: 7, FIREWALL
"Alterations prohibited unless expressly permitted in this section.
Firewall coverings prohibited. Where heater/air conditioning
units have been removed, area must be covered with minimum
.024-inch steel or .032-inch aluminum, including rear hood seal/
flange, as on GM A-body. Minor firewall modifications permitted
to C5 and C6 Corvettes for transmission installation. Roll cage
tubing may run across top or side of inner fender well/strut
tower and attach to frame horn.
See General Regulations 7:4."
