Old 07-30-2021, 01:29 PM   #1
Bruce Fulper
Liked 54 Times in 33 Posts
Default GM A-body rear coil springs
Who sells them?
Bruce Fulper is offline   Reply With Quote
Old 07-31-2021, 04:31 PM   #2
prostockpete1
Liked 90 Times in 52 Posts
Default Re: GM A-body rear coil springs
fyi ... Moog has all sorts of front / rear coil replacements ... I have actually seen in the back of their master coil spring older catalog part #.s with diameters / spring rates
prostockpete1 is offline   Reply With Quote
Old 08-03-2021, 09:36 PM   #3
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Moog. There was an online numerical listing, you can look up the application then go to numerical for rates etc. Also rockauto website lists the specs on most of them. G body and 77-96 b body springs also fit, some cross to a body, but it gives you a wider range of available springs
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
