Old 07-23-2021, 10:35 PM   #1
junior barns
Liked 20 Times in 14 Posts
Default Converter flash
Does a gear change affect converter flash ? Say going from 5.13 to 4.88 or 4.56 to 5.13
junior barns is offline   Reply With Quote
Old 07-24-2021, 08:24 AM   #2
Gmirza
Liked 253 Times in 95 Posts
Default Re: Converter flash
Yes it will. Not a lot, but it will change. It’s just like adding weight. Everything being the same the converter will flash higher with 4.56 than a 5.13. You may not see much change either way with 4.88.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 07-24-2021, 10:19 AM   #3
junior barns
Thanks
Old 07-24-2021, 10:30 AM   #4
Jeff Stout
Liked 704 Times in 281 Posts
I went from a 4.30 to 4.88 and lost 300 on converter.
Old 07-24-2021, 10:42 AM   #5
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Jeff,
How many did the slippage change on the top end?
Stan
Old 07-24-2021, 05:07 PM   #6
Adger Smith
Liked 880 Times in 311 Posts
A different low gear Trans ratio will change stall but not the % slip on top end.
A rear gear will change both stall on the leave and slip down track.
Adger Smith (Former SS)
Old 07-24-2021, 10:22 PM   #7
junior barns
Adger, in your experience How much will it change going from 2.52 to a 2.75 1st gear?
Old 07-24-2021, 10:35 PM   #8
junior barns
Thanks Jeff. What I was looking for on rear gear changes.
Old 07-24-2021, 11:51 PM   #9
Adger Smith
Jr, Can't really put a number to it. too many variables. small engine vs large engine,... where in the Tq curve the original stall was, ect. Each application varies. Change the gear, check it with your original converter and make changes as necessary. Like it has been said before... change one thing at a time and test. Your new gear may not like the stall the other set up liked. Don't forget about the low to second % gear drop may change. That may be where you need some help from a converter. Good luck Test, Test...
Old 07-25-2021, 09:48 AM   #10
Jeff Stout
With gear change the data logger showed the finishline lock up went from 6.5 to 5.5. I liked that part but not the .05 loss on 60ft.
