Liked 12 Times in 7 Posts
I am a newbie to the Stock game, so forgive me if this seems like a goofy question. I have a 1971 Chevelle SS with a 454, and Hooker 2265 2 1/8" headers. They broke at the flange on a recent run, and no one has new ones. Am told by various distributors that the soonest they can get new ones is November. I have found a source for Doug's D331 headers that have them in stock now, and they appear to be very similar to the Hookers. My question for the folks out there is if anyone has any experiences with Doug's headers that they can share with me, to let me know if going ahead and buying these is a wise decision, or should I just wait until November?
My thanks in advance to anyone who answers this. Ron |
Liked 225 Times in 136 Posts
Can you weld the old ones? Or cut the flange between each cylinder. They might even seal better on the head.
It is the tubing that broke, and it is ceramic coated, local welding shop won't touch it.
#4 | |
Liked 805 Times in 245 Posts
Jim Caughlin SS6019 |
Liked 1,943 Times in 584 Posts
I cant imagine it being too hard to weld up the repair. I welded the evac tubes into my collectors with no issues and they are ceramic coated. As long as the tubes are not badly rusted just grind what you can of the ceramic coating with a flapper wheel then bead blast the area and weld as usual.
Mike Pearson 2485 SS |
Liked 1,601 Times in 583 Posts
#7 | |
#8 | |
One of my buddies had a set of coated headers that were badly rusted from the inside. We had to cut some of the tube away and replace it with a new piece. I used the same technique. His was an oddball combo so new headers had to be custom made.The repair lasted several years after that. Like you say its not always easy but it is doable
Liked 285 Times in 87 Posts
Ronnie... I have Dougs Coated Headers on my 67 L88 Chevelle, 69 ZL1 Camaro and recently purchased them for my 70 LS6 Chevelle. The Fit, Finish and Quality have me convinced they are one of the best affordable headers on the market. I originally bought a set of Coated Patriot Headers for my 56 SB BelAir 2 dr. sdn. They were unquestionably the best fitting, best Quality headers I have bought. Doug's and Patriot are both owned by Pertronix Performance Brands. The Doug's are heavier than most but are coated inside and out and have 3/8th's flanges and are 16 gauge tubing, they should last.
Hope this helps...Maurice. |
Maurice - thank you for the feedback, I appreciate it. I bought the Doug's headers.
All others - my thanks to all of you as well, I will keep trying to find a welding shop that will fix them for me. Then I will have a back up set also. Ron |
