Old 06-27-2021, 07:36 PM   #1
rod
Liked 20 Times in 15 Posts
Default MSD pre-set?
does the reluctor trigger just as it going past the mag. pick-up? if not, when?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 06-29-2021, 04:48 PM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: MSD pre-set?
If you're asking while trying to set it up, the timing pointer should be at your desired timing point on the balancer (on the compression stroke), the pickup should be directly over the magnet on the wheel and rotor should be pointed at the #1 post on the cap.
That will at least get you close enough to fire and fine tune with the timing light and pickup adjustment.
S/ST 51
S/C 53
