Old 06-14-2021, 09:53 AM   #1
L78 Nova
L78 Nova's Avatar
Liked 23 Times in 13 Posts
Default ACP #105 Header Question
Is anyone running ACP #105 (small block) headers in a 67-69 Camaro or 68-72 Nova that can provide some feedback regarding ground clearance.
A reference measurement of how far below the subframe to the bottom of the collector.
or
Approximate (vertical) distance from the center of the ports to the bottom of the collectors if not installed.
Wanting to pull the trigger on an order but ACP does not have the info... just says good ground clearance.
I just shot out a pile of cash for stainless works that hang 1-1/2" lower than the old Hookers
Thanks for any help you can provide,,.. Gary
L78 Nova is offline   Reply With Quote
Old 06-14-2021, 04:35 PM   #2
Billy Nees
Liked 7,909 Times in 1,754 Posts
Default Re: ACP #105 Header Question
IF the engine is in the "stock" location then you should have plenty of clearance.
Billy Nees 1188 STK, SS
Old 06-14-2021, 05:09 PM   #3
L78 Nova
L78 Nova's Avatar
Yes, stock mounts. Thanks Billy !
