Liked 704 Times in 281 Posts
Can a regular 200 be converted to a lock up design? If not how can you tell from the outside of trans that it is a lock up style.
#2 | |
Liked 172 Times in 81 Posts
Jim Mantle V/SA 6632
Jim Mantle U/V/SA 6632 |
Liked 455 Times in 147 Posts
Are any Lock up TH 200's legal in Stock Eliminator?
Steve Teeter STK/SS. #620 |
#4 | |
Liked 5,121 Times in 1,952 Posts
Of course , adding that weight to a SB converter, would be a wash, at best, IMO Edit..Jim Mantle: That would be the LH side (driver's) behind the shift shft, unless you had it in a clamp fixture in front of the bench ;-)
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 06-03-2021 at 10:40 PM. |
Liked 169 Times in 53 Posts
I think some of the fast guys are probably running lock up convertors along with steep gearing and a 7 or 8 inch convertor but you're not going to get them or anyone to talk about it..
Bill Bogues 4696 STK |
#6 | |
Liked 4 Times in 3 Posts
The lock up trans if I understand correctly has the tag on the side that is labeled 200C--- also if you look at the input shaft you will see a small straight shaft on the very front appx 5/8" Dia and 1-1/4"long
Liked 216 Times in 77 Posts
Can a race transmission be built out of a 200C that originally had the lock up converter? They are not as hard to find as the non lock up torque converter TH200 units.
Liked 1,583 Times in 582 Posts
I was informed and shown by a former GM transmission engineer that the TH200, Oldsmobile diesel engine powered cars have a beefier case. He had both a standard gasoline engine case and a diesel powered case next to each other. The diesel case was beefier and thicker and also has the universal bell housing pattern. The diesel case was also heavier.
#10 | |
Some guys like the earlier pump design in the non-L/U model, and some like to use as new as possible.. I never saw much difference, and have built plenty of both styles.
