Liked 20 Times in 15 Posts
I just got a new cap & rotor from MSD. the rotor is the old Chevy point type. it has the short 'E' brass tip. which has close to 1/8" gap between the tip and the cap terminal. I know GM used this 'E' rotor for emission engines [thus the E]. doesnt the large gap make it harder on the coil? what is the real purpose of the larger gap?
before I set about modifying the new one, I want to why I shouldnt! thanks Rod in AZ |
Liked 708 Times in 285 Posts
Rod, my understanding having a large cap it helps to not get a miss fire. On the small cap an Arc could jump to either terminal next to the one to be fired. When running on motor and turning on nitrous timing is retarded. With the large cap you can do it safely and not misfire. That's bad on nitrous if it misfires.
#3 | |
Liked 7 Times in 6 Posts
#4 | |
Liked 520 Times in 176 Posts
