I have a 69 coupe. I determined that my 351w isn't a great combo, probably not the 302 2bbl that would be m stock either. And I don't want to mess with 428s either. I do not know a whole lot about super stock gt, but can I use a newer 302 for example with my weight and use that? What if its a 80s fuel injection engine? Does it need to use original style induction, ? Gt fi? I'm just trying to find a direction. Thanks.
Liked 19 Times in 7 Posts
There are more options with a 70 mustang, 351c with autolite carb is a possibility. You have to decide if it is stock or super stock. Gt is only in super stock. It is not hard to make a 69 into a 70.
ss/gt 93 t-bird |
Liked 21 Times in 8 Posts
What combo is the all black SS/GT mustang I think from the northwest. Beautiful car.
Liked 928 Times in 241 Posts
Your options to run GT are wide open. You should go onto classracerinfo.com, and start playing around with engine combos. Dickie Lux is running the 352 pushrod engine from the 2010 Mustang Cobrajet in his car, looks like a pretty good modern combo. Duane Eiskant is running the 73 351c combo in his 85 mustang. Other factors to consider are wether you have or want to put a cage in the car. Thay may limit you on what you want to run.
Good luck and have fun
Duane Hoven 1342 SS/GT |
#7 | |
Liked 949 Times in 262 Posts
I believe that you are talking about the black 69 Mustang notchback, that belongs to Darrell Dietz, from Alberta Canada. I believe it used to be ran with a 428 Cobra Jet in Super Stock, but now runs in SS Factory GT, with a late model DOHC Cobra Jet engine.
I belive the 1970 351C 4 barrel engine is still required to use the "weird" (your words), Autolite 4300 4 barrel carb, which was also used on 69 351W engines, but the 71 & 72 351C can run a Holley carb. The 70 351C engine also has a smaller cam than the 71-73 versions, along with a higher factory HP rating.
