03-30-2021, 12:11 AM | #1 |
Liked 4,578 Times in 1,733 Posts
Ford 302 Rocker Shims
Does anybody have a set that they could measure for me. I think they might work for my application, which looks similar.
Call or email me or just post the length , width and hole dia. 602-769-0346 myac455@gmail.com Thanks
We are lucky we don't get as much Government as we pay for..... Will Rogers |
03-30-2021, 08:21 AM | #2 |
Liked 280 Times in 120 Posts
Re: Ford 302 Rocker Shims
.540 X .865 and the hole is not round, it's .320 X .345
Phil
Phil Molski PMR Performance S/C 1623 |
03-30-2021, 10:41 AM | #3 |
Liked 161 Times in 74 Posts
crane cams i believe has them...
03-30-2021, 11:38 AM | #4 |
Liked 1,458 Times in 544 Posts
Mark,
What diameter and hole size do you need? Prior to the rule change allowing aftermarket rocker arms, I used aircraft AN960 washers in Oldsmobile engine applications. They are available in 0.016, 0.032, 0.042 and 0.063 thickness. They are stronger than commercial washers and still low cost. |
03-30-2021, 11:57 AM | #5 | |
03-30-2021, 12:26 PM | #6 |
03-30-2021, 12:42 PM | #7 |
But it does.. Ford doesn't have any goofy bridges... The rectangle on the pedestal keeps the rocker on center ;-)
03-30-2021, 12:48 PM | #8 |
I suppose you could use washers on a Ford but I'd prefer not to.
03-30-2021, 04:16 PM | #10 |
Liked 370 Times in 102 Posts
Ford Performance also has the pedestal shims ,part # M-6529-B302
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
