Liked 200 Times in 91 Posts
i have a sbc block that was honed years ago...have used different clensers to wipe/clean the walls down, leaving some resadue....will it affect ring seal? tks.
Liked 126 Times in 61 Posts
Auto trans fluid on a rag. Clean until it doesn't show any trace. If its rust you need to hone.
no rust...just stains from the cleaners...dull, not a shinny surface.
Liked 965 Times in 306 Posts
If in doubt hone it.
will do tks guys...
Liked 11 Times in 8 Posts
I have the same issue with a block I had to the machine shop, sat around in my garage for too many years. Now I have a little time, pulled it off the shelf and the WD-40 I sprayed on it to keep it from rusting dried on the cylinder walls. Recleaned it, and didn't like the look of the cylinders.Started checking clearences, and the piston to cylinder wall measurement isn't to my specs. So I am going so send it out to get rehoned again.
Liked 1,538 Times in 575 Posts
The over the counter WD-40 is a water dispersant and was not designed for long term corrosion protection.
However, in the WD-40 product line, they do have a WD-40 industrial product by the name of WD-40 Specialists Rust Inhibitor Lubricant that is for long term corrosion protection. https://www.zoro.com/wd-40-specialis...35/i/G4477243/ Another great corrosion inhibitor is Hornaday One-Shot lubricant. Although it was designed for guns, it is a great long term corrosion protectant for metals. https://www.cabelas.com/shop/en/horn...shot-case-lube |
Liked 6 Times in 6 Posts
Watch, watch, watch: WD 40 is the worst thing for rust prevention. I bought a block that was stored for five years; was told it was sprayed once a year. Machinist gave it back to me & said .030 over will not clean it up; looking for another block. Lost a crank that same way. Grease it up boys; lasts forever!
Liked 347 Times in 79 Posts
also heard kroil in the orange can works good?
