Liked 302 Times in 73 Posts
Hi All,
I'd like to keep this discussion as general as possible to encourage dialogue on the topic. If you're open to disclosing specifics that is totally up to you, but I feel like there are probably a few opinions on this topic and it could be a bit of an interesting discussion. Basic question here is when you have your heads done or you do them yourself in legal stock eliminator form (whatever that means in this day and age to you individually) what is the most important improvement in flow characteristics you are looking for? 80-90% of us have less than .500 lift, so are you looking to see the numbers from .400-500 to jump? Are you looking at port velocity? are you looking at average from specific lift values? something else? This isn't really a discussion on "HOW TO GET THERE" but more with your end results compared to where the heads started stock what makes you decide the heads are going to make you .800 .900 1.00 under capable verse the stock castings? Brad |
#2 | |
Liked 1,599 Times in 583 Posts
Curious what you man by "optimize the valve open and closing events" when it comes to the valve job or flow characteristics of the cylinder head. Maybe I'm just completely naive, but wouldn't this been completely controlled by camshaft design after you already know the flows and velocities of the ports?
Liked 10,781 Times in 2,241 Posts
On the V6 truck engine I went to core suppliers to get the best sets of heads for each approved casting number. How I judged the heads by valve protrusion into into the chamber. I bet I looked at 200 + pairs of heads. I think I had 4 or 5 sets of heads of each casting number to clean and test on my flowbench. Most of my winnings from Atlanta were used to buy the bench Jimmy Bridges did my first set heads for the truck. I think he picked the two best out of six.
Liked 225 Times in 136 Posts
You want a port that continues to flow well past your max lift point and not go turbulent and is quite on the bench!
Liked 22 Times in 14 Posts
I’m not a head guy but with the valves hight in the head, if you had to sink one to get the cc’s correct it usually didn’t hurt the flow real bad. In most of the old cast heads one or two runners are just turds and are difficult to get to respond. I have made a few test valves.
#8 | |
Seen too many heads with big flow numbers and low velocity that do not make power. Your valve job angles are also critical and different for each head manufacturer. The reason why you want to have a good flow past your maximum lift is because you can make more power by doing a controlled loft of the valve past your maximum allowed lift. The cam lobe is designed to toss the lifter and increase valve lift to make more power while still checking legal during a static lift inspection. |
#9 | |
Liked 734 Times in 385 Posts
I have not done an stock eliminator heads but looking at the rules, I do find it interesting what is being talking about. It looks to me the only area one can get creative is the valve job. Stan |
You need to read the gray area part of rules. Most of the heads are ported( acid and others ways the camouflaged) to pass tear downs!
