Liked 232 Times in 69 Posts
Looking for some recommendations for front shock issues. 67 Camaro, Moroso trick front coil springs, Steel headed big block Chevy, turbo 400, full interior, 3700 #'s with 200 # driver. Car wheel stands 2-3 feet in the air. 60 foot 1.35-1.37, Actually tripped the 60 ft. timer with the back tires this passed week. The problem is the landing. It bottoms out the suspension so bad that it's actually knocked the head lights out of the car, and cracked one of the header tubes. I use Afco 3840F/BNC front shocks. They have been sent back to Afco several times, to be re-valved to fix this problem, with only minor results. I'm beginning to wonder if I'm passed the point of the Afco shock's ability to control the landing. I know there are several Stock and Super Stock cars doing 2-3 foot wheel stands out there. I understand I am 200-300 pounds heavier than a typical big block Camaro, but there must be a way that these other cars are dealing with this issue better than my situation. Looking for suggestions. Thanks.
Liked 239 Times in 114 Posts
Do you have wheelie bars ? How far do they sit off the ground ?
Either send your current shocks to Randy at FastShocks or talk to Marty Rinehart at Rinehart Performance for the proper Santhuff shocks and front springs.
#4 | |
Liked 502 Times in 130 Posts
Now if you like the challenge of ripping of a 00light when your car/truck is going to the moon, you are going to have to compromise a touch so you can dial that beast. Don't cheap out on the front $ wise...... Changes like a bit of weight up there, running it less extention, lowering those bars not tough...... Myself excluded of course, I'm ripping it and in a foul mood if I don't 60 foot on the rear tires.(truck only) Eric
Eric Merryfield 1883 STK |
Liked 2,745 Times in 969 Posts
How does the wear and tear of towing effect the sustainability of racing shocks?
Liked 312 Times in 175 Posts
I'm a believer that the front shocks are more important than the rears and I would spend the money on Santhuffs because their valving / internal design can be adjusted to control the bounce from large wheelies. JMHO
#8 | |
Liked 171 Times in 36 Posts
I don't have any experience with Fastshocks, but I have heard good things about them as well. |
Liked 436 Times in 116 Posts
I use Santhuff shocks on both of my cars and i sell and stock them as well, if ya need any or have any question, Thanks Brian, 407 474 0898
Attachment 56409
Here is a photo of the car this past weekend Last edited by NHRA1926; 03-23-2025 at 06:26 PM. |
