Old 11-06-2007, 10:35 AM   #1
Bill Pomponi
Default Aluminum Brake Drums
Has anyone seen an advantage utilizing rear aluminum brake drums vs. OEM ?
Bill Pomponi is offline   Reply With Quote
Old 11-06-2007, 11:24 AM   #2
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
Default Re: Aluminum Brake Drums
.05
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 11-07-2007, 05:50 PM   #3
Jim Kaekel
Liked 530 Times in 108 Posts
I didn't get any noticeable e.t. out of them. A friend that worked in a muffler and brake shop for over 20 years warned me that they would crack once in a while on OEM applications. I pulled them off after two or three races to check them, and both were cracked! I "installed" them in the trash bin after that. If I recall, my pal Kevin Zaskowski put his car in the sand at Indy after one shattered. My .02.
Jim Kaekel 3836 STK
Old 11-07-2007, 06:29 PM   #4
David Lee
Liked 346 Times in 126 Posts
I was consering putting in disk brakes on the back of my Nova project. I assume that the braking would be better and I would also lose the same amount of weight. Would I be correct on this assumtion?
Old 11-07-2007, 06:38 PM   #5
Harry 6674
Most of the time OEM discs will be heavier than drums but the aftermarket brakes can be lighter depending on application.
Harry 6674 is offline   Reply With Quote
Old 11-07-2007, 06:43 PM   #6
David Lee
I was going with the willwood setup, I should have mentioned that.
