Liked 18 Times in 8 Posts
I've never seen this mentioned before, When you set your timing on your crank trigger then set the distributer on number one plug how far can you advance or retard the crank trigger before you have adjust the distributer again ? Or you must adjust the distributer every time ? Thanks< By the way I'm not talking big changes just 2 or 4 Degrees
