Old 09-13-2020, 02:08 PM   #1
e vassar
Liked 281 Times in 110 Posts
Default Digital Voltmeter Wiring
I ran across a digital voltmeter in a old tool box. I don't remember where it came from. I put the red and black wires across a battery, and it works! Even flashes on and off under 12V. So I think im going to install it in my car.Here's my question. There is also a purple wire on it. What could that be for?
Old 09-13-2020, 02:29 PM   #2
T Ames
T Ames's Avatar
Liked 125 Times in 33 Posts
Default Re: Digital Voltmeter Wiring
It’s likely lighting.
T Ames is offline   Reply With Quote
Old 09-13-2020, 05:30 PM   #3
e vassar
It IS lighting. But not backlighting since it is digital. So when there is no power on the purple wire, the display is bright . When power is on the purple wire,the display dims.
My car has no master cut off switch and I normally do not disconnect the battery, the gauge will display forever, so I hope the parasitic draw is tiny.
Old 09-13-2020, 06:48 PM   #4
Painter
Liked 162 Times in 45 Posts
If you have msd ignition, they live a lot longer if you disconnect the battery at night and after you leave the track.
Painter is offline   Reply With Quote
Old 09-13-2020, 06:52 PM   #5
e vassar
Its Big stuff 3 and coil packs.
Old 09-13-2020, 09:35 PM   #6
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Everett, the purple is to dim it, if I’m remembering the ones I had before, correctly. I just capped them, with a crimp end.
2894 STK
Old 09-13-2020, 09:49 PM   #7
e vassar
Kenny..now I remember where that gauge came from..It was in that center console in the Cutlass!..along with 16 miles of wiring LOL. I found a new home for it.
Old 09-14-2020, 11:46 AM   #8
Dragsinger
Liked 99 Times in 60 Posts
the purple wire is an option to dim the display when the lights are on. You can connect the purple wire to a tail light or park light on wire.
Larry Woodfin 471W
Old 09-14-2020, 01:04 PM   #9
voltdr
Liked 100 Times in 51 Posts
Huh?????
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
