Old 08-26-2020, 01:45 PM   #1
tylerw5089
Liked 31 Times in 7 Posts
Default 2000 Pontiac Firebird AA/SA-B/SA
Originally built by PK Race Cars, Ohio title, GM LSX block, Callies Rods, CP Pistons, Harland Sharp Rockers (New 2020), PAC springs, Heads and Cam (Bullet) by Sherman Racing Engines, billet valve covers, GM coil packs relocated, Scott plug wires (New 2020), Accufab throttle body, Red Top Optima battery (New 7/2020), Coan Converter (Freshened 8/2020), Wudarczyk Performance Engineering Metric 200 (Freshened 8/2020), Victory Performance aluminum driveshaft (New 3/2020), 12 bolt housing, Strange 33 spline axles (New 2019), 5.13 gear, LPW rear end cover, Competition Engineering wheelie bars, HAL rear shocks single adjustable, Joe Russell traction bars, JAZ fuel cell, Aeromotive A1000 pump, Aeromotive regulator, Afco double adjustable front shocks by FAST, Mark Williams brakes all four corners (New 2019), Global West front suspension bushings, Stainless step headers (New 8/2019) with Performance Welding merge collectors, Kirkey seats and factory seats, K&R switch panel and relay board (New 2018), FAST XFI 2.0 with EZ-LS, Autometer Gauges, Precision shifter, Weld V-Series wheels.
Engine freshened prior to 2020 season, has less than 50 runs on it at this time. Dyno Sheet available to buyer. Car will be at U.S. Nationals
Spare Parts
Stainless headers, Panhandle Performance Engines LS heads, A-1 converter, stock throttle body, factory seats, non-Ram Air factory hood (to run B/SA)
$32k
78 Five- 55 Zero-Two741
Tyler Wudarczyk
tylerw5089 is offline   Reply With Quote
