Old 10-31-2007, 03:47 PM   #1
Rusty Davenport
Liked 100 Times in 26 Posts
Question Q-jet air horn tube----removal issue
For hood clearance I want to run the carb with the air horn pulled completely out----does that create any kind of a problem with the carb ??? Would that make the carb illegal in superstock for any reason ???
Rusty Davenport is offline   Reply With Quote
Old 10-31-2007, 05:03 PM   #2
Mike Hedger
Default Re: Q-jet air horn tube----removal issue
Choke air horn?
Mike Hedger S/C 4646
MPH Racing and Fabrication
Mike Hedger is offline   Reply With Quote
Old 10-31-2007, 06:10 PM   #3
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Q-jet air horn tube----removal issue
Rusty,
Get ahold of Danny Ashley (765-674-5102) @ Q-jet carbs,I think that his number... Dave...1033/stk
Dave Ribeiro 1033 STK
Old 11-01-2007, 09:24 AM   #4
Rusty Davenport
Question Re: Q-jet air horn tube----removal issue
for clarification----the 3/8" metal tube that sticks straight up on the front top of the carb-----some guys attach a 90 degree elbow to it and point it to the front of the car----it will pull out of the carb if you treat it nicely without crushing it. Can I remove it completely ?????
Old 11-01-2007, 11:27 AM   #5
Uncrated
Banned
Rusty,
in ref to removing the vent tube without cruching it. Find a punch or bolt or what ever that just slips inside the tube. Then grab the tube with vice grips and twist, it will ease right out. Having the punch or other spacer inside the tube keeps it from crushing. This also works with dip stick tubes and Holley carb vent tubes.
Hope this helps.
Larry Woodfin
Uncrated is offline   Reply With Quote
Old 11-01-2007, 02:27 PM   #6
Rusty Davenport
the BIG QUESTION is does it effect the carb performance not to have it in ???? and is it required to be legal ?????
Old 11-02-2007, 06:43 PM   #7
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
The guys who extend the vent tube forward are correcting a specific problem- the float level is high (on purpose), and raw fuel sloshes up and out the vent tube under hard acceleration, then it seeps into the primary venturi. So, yes, this could effect performance under some circumstances. Only one way to find out for sure, try it. You can always put the tube back in.
As for its legality, that seems like a matter of interpretation, so you may as well ask your division tech. A strict constructionist will probably say no, but it doesn't make the car go faster, so who knows.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 11-03-2007, 08:40 PM   #8
ZASKO
Best way to remove is take off the AIR HORN (the top) then tap the tube from the inside. There is no performance gain with or without the tube.
Z-man zzzzzzzzzzzzz
ZASKO is offline   Reply With Quote
