Liked 707 Times in 284 Posts
I wired in a 2 step on this box. I connect 2 step between grey wire and tach and cant get it to work. Blue wire connected to button on brake pedal Im lost. Help!
Liked 314 Times in 177 Posts
You should have 4 wires from the 2 step. Grey tied in to tach and Ign box, Red to 12 v, Black to ground and Blue to switched 12v ( normally open ).
Liked 93 Times in 52 Posts
Was it a new 2 step? No red light when activated by 12v on the blue wire?
???? Did you check with a volt meter that you are energizing it with 12 volts? You maybe losing voltage if your going through a brake light switch. That's all I got.
Figure it out?
