Old 07-15-2020, 12:19 AM   #1
littlemanjoe
Liked 75 Times in 28 Posts
Default Stock Eliminator headers
Has anyone tried the TTI full race step headers with merge collectors on their stocker?
Is it worth the money for stainless Tri-y's?
littlemanjoe is offline   Reply With Quote
Old 07-15-2020, 12:21 PM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Stock Eliminator headers
I've always run the TTI small block step headers (1 5/8" - 1 3/4") on my IHRA car. Originally with collector extensions, then a full exhaust with an X-pipe that helped my combo. Several others have TTI on their NHRA combos including some that have added merge collectors. But I haven't run anything else to compare them to.
LOCOMOTION Racing
Old 07-15-2020, 02:57 PM   #3
SSDiv6
Default Re: Stock Eliminator headers
If you want the best performing Mopar headers...Mark Lelchook at Performance Welding
Old 07-15-2020, 06:03 PM   #4
340Cuda
Liked 805 Times in 341 Posts
I would also recommend Mark and I believe he only does stainless. However whomever you use I would recommend stainless or headers that were very well coated inside the tubes.
I listened to a webinar a few weeks back and Jon Kaase was one of the guests. He said they can look at an engine in their shop and tell if it had mild steel or stainless headers.
He went on to say that if a car sits for very long with mild steel headers rust forms inside them. We have all seen this. However he went on to say that any car with a cam much bigger than stock will do a very good job of vacuuming out the headers when the car starts and that rust will end up in the cylinders and even as far up stream as the carburetor.
Got my attention.
Old 07-15-2020, 10:22 PM   #5
littlemanjoe
Got my attention.
You wouldn't think it would pull it into the engine, interesting.
Thank you for sharing that.
Old 07-16-2020, 01:00 AM   #6
bykr
Liked 167 Times in 81 Posts
Yeah, that webinar was good.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 07-16-2020, 09:51 PM   #7
Dave Gantz
Liked 251 Times in 125 Posts
Got my attention.
I put rags in my collectors. I've done it thinking I was keeping moisture out of the engine. Never thought of the rust sucked into the engine aspect. Ouch. I wonder if the rags help?
Old 07-17-2020, 01:23 PM   #8
RonP
Liked 29 Times in 14 Posts
Smile Re: Stock Eliminator headers
Try KromerKraft in Youngstown, OH,...330-539-5053
Stainless should not require a coating, but mild steel should be ceramic coated to prevent rust.
RonP is offline   Reply With Quote
Old 07-17-2020, 01:50 PM   #9
340Cuda
To be 100% you probably would need something like this, if Dan still sells them.
http://www.dvorakmachine.com/essstorage.shtml
Might be easier just to pull the headers and get a good coating on them.
