Old 07-04-2020, 04:49 PM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default Running LS engines on break-in stand
I have an engine run stand that we test and break-in 1st and 2nd Gen SBCs. What do people do to run LS engines with throttle bodies and stock intakes? I know there are total after market setups but does anyone use a system from near stock parts to run these engines? Can the Edelbrock ignition box be used with a stock ECM and harness? I keep dragging things home from the junkyard and want to test stuff too. Think it was 100 degrees today but I found a 6.0 LQ4 and had to pull it before it disappeared. Thanks.
brian schuetta is offline   Reply With Quote
Old 07-04-2020, 04:54 PM   #2
brian schuetta
Default Re: Running LS engines on break-in stand
The more I look at this the throttle becomes problematic.
Old 07-04-2020, 08:30 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
www.howellefi.com makes wiring harness conversions to run the stock ecm , that eliminate the vats system , and other non essential systems
Old 07-07-2020, 08:53 PM   #4
Kevin Musial
Liked 10 Times in 3 Posts
Brian,
Tried to send you a PM, but your box is full. I may be able to give you a hand with this. We met last year at Alamo City Motorplex at the bracket race and I'm local to you. Send me a PM and I'll give you my contact number.
Kevin
Kevin Musial is offline   Reply With Quote
