Old 06-25-2020, 02:25 PM   #1
Cotten
Liked 556 Times in 69 Posts
Default Q jet storage boxes
Does anyone know of a good storage/ carrying care for q jet carbs? Will the cases designed for 4150 holleys work?
Thanks
Cotten is offline   Reply With Quote
Old 06-25-2020, 03:24 PM   #2
GTX JOHN
Liked 2,457 Times in 693 Posts
Default Re: Q jet storage boxes
Mike: I went to a 99 cent store and they had a plastic container the perfect side. I put a zip up plastic bag around the carb and newspaper rolled around the outside. I can put 1/2 dozen carbs in a plastic tote container.
The way I build carbs = I need a lot of spares!
John Irving
741 Stock
741 Super Stock
Old 06-25-2020, 10:04 PM   #3
Dale Hulquist
Liked 350 Times in 75 Posts
Mike, Kris and i just found some multipurpose real nice hard plastic carring cases (Apache 2800) at Harbor Freight Tools they have the pre-cut foam inserts that are easily customized to fit carbs, pistols, and are very durable.
Dale Hulquist
4006 Stk
4006 S/Stk
Dale Hulquist is offline   Reply With Quote
Old 06-27-2020, 11:47 AM   #4
SSDiv6
Liked 1,552 Times in 577 Posts
Originally Posted by Dale Hulquist View Post
Mike, Kris and i just found some multipurpose real nice hard plastic carrying cases (Apache 2800) at Harbor Freight Tools they have the pre-cut foam inserts that are easily customized to fit carbs, pistols, and are very durable.
If you use the Harbor Freight box, just be careful if the carb has fuel; it will damage the foam and create a mess. Just purchase some fuel cell foam, cut it accordingly and replace the foam that comes with the box.
For spare QJ parts, I use the Harbor Freight plastic box with the inserts. It has different size compartments that allows to place the rods and other parts.
https://www.harborfreight.com/18-div...ium-94457.html
