i have a 33-3400# 69 camaro that is a drive to the track street/strip car,motor made 752hp at 6400 and 670 ft lbs at 5200,548" pump gas bbc,the trans is a g-force 101 4 speed [2.98 first],i have 4.29's out back,32" tire with double adj coilovers and ladders.just got the car to the track last week,best pass after finding a decent clutch tune [10.5 sintered],10.05 at 135 with a lousy 1.43 60'er,1/8 mile is 6.42 at 109+
i launch the car at around 6000,and it quickly pulls the motor down to around 4000,and obviously struggles to recover,except for those runs with clutch or tire spin,which don't help the 60' much i will go as far as a 4.71 rear gear as i can still go 60 on the highway and only turn 3000,and turn 6800 IF i ever get 137 mph in the traps does anyone have a good simulation program that will tell me what 60' improvement can be had with this gearchange ??? also,can switching to a steel flywheel with more stored energy keep the rpm's from dropping to 4000,or is the effect really only good for a few hundred rpm's???? thanx |
only thing about that is my counterweights will kick in and provide too much clutch
Liked 3 Times in 2 Posts
It appears that you have too much base pressure to launch at 6000 rpm. You might try 5000 and see where the rpm comes back to. You will get your best times with the engine pulling back 200 rpm or less. Otherwise, you will have to have a data logger to get close on the clutch set up.
Arnold Greene IHRA/NHRA 2420 A/S, B/S |
I would suggest you contact Rob Youngblood @ www.advancedclutches.com. He will sell you the right parts and his consultation to his customers is absolutely invaluable.
He'll show you how to make that 135 turn into at least a 9.60. You've probably spent a ton of money on the car thus far. Now it's time to make it work with the right clutch! Good luck. Try the http://www.umtrnorth.com/ forum also. That's the United Manual Transmission forum also.
Jeff Lee 7494 D/S '70 AMX |
thanx for the replies!!!
