Liked 181 Times in 111 Posts
Before racing this weekend.
Scrubbed and clean the Featherlite Trailer with Cleanser. Did ok Got most of the mildew. It needs a better cleaning. What product is out there that does a good job? Dan |
Liked 282 Times in 152 Posts
try simple green --just spray it on let it set a minute then use one of those windshield bug scrubby sponges and use a soft toothbrush in the corners ---rinse immediately top to bottom--do a section at a time don't try to do the whole side all at once---FED 387
#3 | |
D |
Liked 133 Times in 28 Posts
I found that 5% distilled white vinegar and 95% water and a scrub brush cleans and stops the mildew.
Also, after scrubbing, don't rinse it off right away to allow the vinegar some time to kill all the mold. About an hour should do. A gallon of pre-mix can be bought in most grocery stores for under a dollar. Good luck. Chuck Last edited by Chuck Gallagher; 08-12-2020 at 09:14 AM. Reason: clarification |
#5 | |
Liked 262 Times in 74 Posts
Go to the Dollar tree/ Dollar General and get some "LA's Totally Awesome". Its a yellow cleaner in a clear bottle. I buy it by the case. Don't spray it full strength on the trailer, It will leave clean streaks where ever the cleaner was. I mix a bottle of it in the bucket every time I clean the motorhome or trailer. That stuff will clean anything, I use it in the washer with my work clothes, to clean the BBQ etc.
Steve Polhill 3520 STOCK, COMP |
Liked 685 Times in 293 Posts
Any recommendations on something that works well with a power washer?
Thanks, Bill |
I brush and a bucket LOL
Liked 53 Times in 33 Posts
Just purchased a trailer from Texas that had been stored outside all of its life. Great little trailer but in dire need of cleaning.
So........after trying Simple Green and then Totally Awesome, (diluted), in conjunction with a medium stiff scrubbing brush and warm water, it was clear this wasn't even coming close to touching the water stains. I tried the following: Variable speed buffer and medium sponge buffing pad with 3M #1 rubbing compound mixed down with water. It took about 6 hours and a 12 pack to complete. Worked for me.......
SC 707Y |
Liked 6 Times in 4 Posts
Totally Awesome is very aggressive and I think it removes the wax... I use it right before I am going to wax my trailer. Gets rid of black (I have a white trailer) streaks, What ever you do, don't let it dry on the trailer.....
