Liked 800 Times in 237 Posts
Any thoughts on low drag wheel bearing grease for tapered front bearings?
Also, there used to be a company (Sealsit, possibly?) that made a sealed bearing conversion for inside/outside tapered bearings? Thanks! -Al
"That'll never work....." |
Liked 131 Times in 24 Posts
I use the low drag grease from Lamb
Denny Steward GT/JA 246 |
Liked 167 Times in 81 Posts
Synthetic grease (Valvoline I think) available at O'Reilly's
Tim Schmackpfeffer 762 SS |
Have used the Lamb grease before, however, there are improved products with new formulations such as the following:
https://www.microbluebearings.com/me...ody-lubricant/ https://www.speedwaymotors.com/DRP-0...ms,383149.html |
Liked 129 Times in 53 Posts
When visiting Lambs shop several years ago I told him you are using the the same grease we use on our commercial jets and he quickly responded that's because that grease is designed to go from a stand still to 150mph in a second
![]() Never really thought about it that way before he said it! Dont know if that is the same they use today.
Stop global whining |
Liked 8,216 Times in 1,537 Posts
It’s always a GOOD DAY when talking to Betty Lamb on the phone. One winter during our conversation I told her it was 20 degrees here at home....She asked me WHY on earth would you live there ? Honestly, I didn’t know what to say....I do use and recommend their wheel bearing grease.....
Liked 370 Times in 101 Posts
Jerry Bickel, and some other chassis shops sell this Mobil 1 # 28 synthetic grease
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#8 | |
The aircraft wheel bearing grease has a viscosity grade of 5. The normal dyno based, non-synthetic bearing grease is 2. The Lamb grease appears to have a viscosity of 1. MicroBlue has 00, 0 and 1 viscosity grades available. |
Liked 73 Times in 36 Posts
A very good bearing grease for racing only is Kluber Lubrication Isoflex NBU 15. It is expensive, but very good for the application.
Regards to all that like this kind of stuff, ![]() HB2 ![]() Dissident |
Liked 77 Times in 39 Posts
Speaking of wheel bearings don't forget the ones on your trailer.
