Old 05-25-2020, 08:56 AM   #1
Gmirza
Liked 251 Times in 93 Posts
Default Master cutoff switch
I’m looking to install a 4 pole master shutoff switch, who makes a good one from both a quality and price point?
I am running a power master 30/50 amp alternator, and two 525 amp batteries, what do I need for a continuous rating?
Thanks for looking.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 05-25-2020, 12:12 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Master cutoff switch
Thanks for looking.
I had a Moroso 4 pole that worked until it broke. I replaced it with a Flaming River two pole and wired the alternator to the battery side of the switch with 4 gauge welding wire. It disconnects from the electrical system along with the battery positive and I don't get any run-on. The Moroso wasn't cheap. The parts store rotary switch I used for a week was and came apart. The FR is like comparing a weight lifter to an underweight kid.
EDIT: This is something that tech checks 100 percent of the time. Build it solid.
Dale Shearon
68 Mustang 6394
Old 06-24-2020, 12:20 PM   #3
OkieRocket
OkieRocket's Avatar
Liked 6 Times in 5 Posts
Take a look at Cole-Hersee # 75912-BX.
OkieRocket is offline   Reply With Quote
Old 06-24-2020, 01:18 PM   #4
pmrphil
Liked 345 Times in 149 Posts
Taylor 1033 would be one to look at, 4 terminal, high amperage.
Phil Molski
PMR Performance
S/C 1623
Old 06-24-2020, 10:16 PM   #5
Gmirza
Thanks guys,
I used a Joe’s 4 pole 250 amp from summit. I ran the batteries through one side and I put a painless cv solenoid in the alt-batt. Line and ran the activation power wire through the other poles. It works perfect, shuts the car down and kills all the live power in the car.
I tried running the alt-batt wire through the switch but I was getting a big voltage drop at the batteries. Just to much wire length, the solenoid solved that problem.
George Mirza
D/SA 1236
‘71 Duster 340
