Old 05-23-2020, 10:50 AM   #1
L79racer
L79racer's Avatar
Default Helmet and glasses?
So as I now need my glasses on to see my gauges. I have a problem with the helmet foam interfering with my glasses. Glasses dont sit or stay in right place. Anyone else have an issue? Buy a larger helmet or cut out some foam are my only two options I see. Pain in the *** getting old.
L79racer is offline   Reply With Quote
Old 05-23-2020, 11:17 AM   #2
james schaechter
Liked 1,436 Times in 299 Posts
Default Re: Helmet and glasses?
I have a Bell helmet that has a large opening and I use glasses. My Simpson super bandit is ok as well, if your gauges are really mounted low, it can be hard to see them, especially with a neck collar. You might consider moving them if that is the case.
James Schaechter 3163 STK
Old 05-23-2020, 12:53 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Just a suggestion from someone who lost a lot of $$$ once looking at gauges instead of where he should have , put in warning lights for the oil and temp, you will see them long before the gauge anyway. I used 2 temp senders to let me know if I had reached my desired temp and one for too hot.
I even advise my customers to loose the old 5" tachs in favor of digital tachs with multiple shift light settings .
much easier to see a light come on when staging instead of the tach if you launch on the converter instead of a 2 step .
Old 05-23-2020, 06:09 PM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
I like the glasses with a straight temple instead of curved behind he ear. Much easier to deal with in the helmet
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 05-23-2020, 06:50 PM   #5
Ernie Neal
Ernie Neal's Avatar
Liked 328 Times in 80 Posts
When I used to have that issue, I switched to the wire frames that gave a little more and was able to work with all those problems. I had multi-focal contacts for a while. I had to give them up because of always fabricating.
Now that I have had the cataract surgery and the yag procedure, don't need anything but sunglasses and readers. Still can't cut a light though.
Ernie Neal
SS 354
Old 05-23-2020, 07:00 PM   #6
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
I use the Bell full face helmet with the large opening. Works pretty well. Haven't had any issue with my glasses, other than the occasional fog up, using that helmet.
Jeff Jewell
Old 05-24-2020, 08:20 AM   #7
Weekend Racer
Use Simpson Balaclava.
Weekend Racer is offline   Reply With Quote
Old 05-24-2020, 05:54 PM   #8
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
For the budget minded, a Zamp full face works as well.
Lane Weber
Old 05-25-2020, 12:17 PM   #9
Pistol Pete
Pistol Pete's Avatar
Liked 795 Times in 210 Posts
I used Armani Exchange hard frames with an open faced helmet.
Glasses worked fine.
"Pistol" Pete Dutko
