Liked 71 Times in 38 Posts
Are there any real advantages to using a roller vs. a Babbitt bearing? I’ve never had any personal experience using them.
Liked 358 Times in 83 Posts
Really interesting question. A person's intuitive reaction would be "of course, look at things like roller lifters and rockers", but I'll bet there aren't many engine builders who have actually done an A-B-A comparison of cam bearings.
Babbitt is the only way to go.
Roller bearings, when turning the camshaft on the engine stand, the camshaft feels drag free and it turns easily. However, during engine operation and load, there is more drag while turning. When using high spring pressures, the loading may cause the needle bearings to fail. |
Liked 54 Times in 24 Posts
The biggest advantage of roller bearings are that they do not need pressurized oiling. So in most V8's you are blocking off 5 oil leaks inside an engine.
Todd Gross 3323 FS/E,F |
Liked 372 Times in 129 Posts
Liked 200 Times in 62 Posts
My engine guy told me that Jesel experimented with roller cam bearings and the negative harmonics were real bad. That was quite a few years ago, maybe someone found a way to correct?
#9 | |
If you have the right cam journal an lifter bore clearance, you will not have to worry. Yes, they are known to create harmonics issues and it shows in Spintron testing. Last edited by SSDiv6; 05-16-2020 at 05:08 PM. |
Liked 584 Times in 94 Posts
Not Legal in Stock ,,, correct ?
