Old 04-08-2020, 10:45 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default Fast xfi rpm issue
Fast xfi, analog 7al2, fast dual sync dist. My autometer tach is roughly 500rpm less than what fast data shows. Fast at idle shows 1100 while tach is around 600. Is this normal or if not, what is the fix. I honestly thought I had a low reading tach before I put on efi, just now I have another reference that should be super accurate since its dual sync
jamie2370 is offline   Reply With Quote
Old 04-09-2020, 08:26 AM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Fast xfi rpm issue
Sounds more like an Autometer issue.
Ed Wright 4156 SS/JA
Old 04-09-2020, 08:34 AM   #3
jamie2370
I agree, I think I will try another tach to see. Like I said, when it was a carb combo I really thought it was off then but I had nothing to compare it to
Old 04-09-2020, 09:25 AM   #4
GUMP
Liked 2,323 Times in 546 Posts
Where are you picking up the tach signal?
Old 04-09-2020, 09:57 AM   #5
jamie2370
at the 7al2 box, tach terminal
Old 04-09-2020, 10:34 AM   #6
GUMP
Is there an unused tach wire on the FAST harness? If there is, it would be worth trying before changing the tachometer.
Old 04-09-2020, 10:36 AM   #7
Signman
Liked 269 Times in 99 Posts
Have you tried the tack output in the XFI harness if I recall is the white points wire
Old 04-09-2020, 11:31 AM   #8
Ed Wright
Ed Wright's Avatar
I have not had a tach in my car for a while now. I log & play back every pass. If I had a stick car, I would need one, wouldn’t I? Or a shift light. LOL
Old 04-09-2020, 02:57 PM   #9
jamie2370
That's what is firing the msd box. Seems the more people I talk to I am thinking it's a tach issue. Nobody seems to have this problem. And a Tach is a necessity in Stock. Foot brake, and reverse pattern ATI 350 means it's all on me lol
Old 04-09-2020, 08:57 PM   #10
Ernie Neal
Ernie Neal's Avatar
Liked 322 Times in 77 Posts
I have used a digital hand held tach that uses a small piece of reflective tape on the damper to verify which is correct.
Ernie Neal
SS 354
