Old 04-02-2020, 05:07 PM   #1
TimKGillespie
Liked 38 Times in 9 Posts
Default Onan Generator Help
Onan 5500 diesel generator...cranks but won't fire. Let off the switch and it dies. Just changed air filter, fuel filter, and oil and filter for regular Winter service.
If I make it crank until it times out it spits out code 32...which is low battery during cranking. Batteries are at 13.66 volts. Even started the coach and let it run and tried it as instructed in the manual...no better.
I know there are some RV service guys on here...any help would be great!
TimKGillespie is offline   Reply With Quote
Old 04-03-2020, 11:39 AM   #2
MR DERBY CITY
Liked 8,189 Times in 1,536 Posts
Default Re: Onan Generator Help
Tim, Rich Beibel is one of many ONAN go to guys on this forum. He is very helpful. Perhaps you could PM him if he doesn’t see this post....
Old 04-05-2020, 11:28 AM   #3
voltdr
Liked 100 Times in 51 Posts
I had a similar problem with my Onan 7500 last year. Mine is a gas version. My problem was that the drive belt broke and the generator would not rotate with the engine. Onan's have to detect AC voltage to keep the engine running after you release the start switch. It may be the belt, brushes, or anything that doesn't let the generator produce AC.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 04-06-2020, 10:08 AM   #4
Rich Biebel
Rich Biebel's Avatar
Liked 553 Times in 216 Posts
PM sent with some info Tim.....
I reread your above post....
You may have worn brushes......no output....won't run....
Brushes are on left side under a cover......
Rich Biebel
S/C 1479
Stock 147R
Old 04-06-2020, 04:02 PM   #5
TimKGillespie
And I assume taking the cover off will show me if the belt is broken as well...no rotation.
Didn't get the PM yet...maybe wrong Tim?
Appreciate the help...
Old 04-06-2020, 04:35 PM   #6
Rich Biebel
I’ve never seen a belt break on a 5500 diesel.
If it has no output it will shut right down.
Put a voltmeter on the machines AC output wires as close to the machine as you can get. Terminal strip at rear left upper corner under cover is AC output.
If it starts even momentarily you should see AC output.
If no output the brushes are the first thing to check next.
Top cover off allows you to see the belt. It’s at the back of the machine, look straight down.
Brushes are the same ones used on gas machines. They wear or fail regularly. If they did fail you will need to sand the rotors slip rings for sure. A piece of sand paper taped to a wooden stick works well. I use paint stirs and cut strips to fit.
If brushes are ok it gets more complicated.
Rich Biebel
S/C 1479
Stock 147R
Old 04-06-2020, 05:00 PM   #7
TimKGillespie
Well I'm your first then...belt is broken. Based on the way it suddenly quit, I suspected voltdr was probably right. Took the brush cover off and cranked it, fan did not spin. Reached in to the pulley on the generator input and there was no belt. I was able to feel around and grab the belt and remove it. Now I have the part number. Getting the back panel off and the belt on will be a treat in my coach...
Thanks for both your help...
Old 04-06-2020, 05:55 PM   #8
Rich Biebel
Yes that’s a first.
It’s a pretty HD belt.
Check to make sure nothing dropped down in there and caused the failure.
On some machines the battery charging voltage regulator/rectifier is mounted above the belt. The mount breaks from vibration.
They are not fun to work on. Very compact units and very busy inside.
Just about every machine I repair in MH’s has to come out to fix. Very little access.
If you can fix it without pulling it out that’s a plus.
Rich Biebel
S/C 1479
Stock 147R
