Old 10-24-2007, 05:40 PM   #1
Michigan Skip
Default LT1 questions
What distributor are you guys running? The stock opti or the Dynaspark or what?
What PCM are you guys running? Holley, Fast, stock or what??
Thanks
Skip
Michigan Skip is offline   Reply With Quote
Old 10-29-2007, 01:41 PM   #2
Woodro Josey
Liked 3 Times in 1 Post
Default Re: LT1 questions
Skip, stock has to use the OEM type optispark, and i use the MSD Cap and Rotor! As for the Fuel Managment, i use the Holley system! Hope this helps!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 10-30-2007, 03:26 PM   #3
Michigan Skip
Thanks for the info! Do you just use the stock opti with the MSD guts? I've heard the stock units aren't any good above about 6K rpms.
