Liked 660 Times in 283 Posts
55-86 Small Bock. What brands do you like?
Thank you, Mike |
Liked 772 Times in 231 Posts
Mike, I use the cheapy Pro Comp/Speedmaster aluminum one. I did substitute button head screws for the supplied Allen head cap screws as the button heads better fill the recess for the hole. Also, I cut off the front oil pan sealing lip and used the steel ring from a two piece cover to seal the front of the pan. The aluminum cover just seals flat to that.
Just got off the dyno....takes maybe 10 minutes at most to change cam timing, including a couple sips of coffee. Siliconed the lower bolt hole closed (behind the damper) to make things easier. Also made a Lexan cover for it for some other things we were interested in looking at ![]() ![]() ![]()
"That'll never work....." Last edited by Alan Nyhus; 03-24-2020 at 08:00 AM. |
Liked 129 Times in 24 Posts
#4 | |
Liked 680 Times in 269 Posts
Liked 396 Times in 126 Posts
Three piece Comp cover along with their adjustable adv/ retard cam gear. Way easier to adjust. Still need to verify using a degree wheel where the lobe centerline is and where it needs to move to, to achieve the desired cam position.
Steve Teeter Stk M/SA 6380/6283 |
Thank you for the replies.
I chose Cloyes hex adjust and their cover. MJ Last edited by Mike Jones; 03-29-2020 at 03:54 AM. |
