03-10-2020, 07:19 PM | #1 |
Liked 176 Times in 63 Posts
Calvert split mono leaf springs?
Anybody use the Calvert Split mono leaf springs? How much better are they than stock? What are the advantages? thanks
03-10-2020, 08:53 PM | #2 |
Liked 2,328 Times in 458 Posts
Re: Calvert split mono leaf springs?
Looks like you need to get to a race and check out most of the leaf spring stockers. Who doesn't use them. BP
03-10-2020, 09:21 PM | #3 |
Liked 234 Times in 88 Posts
If you plan on using Caltracs they are what you want to use. You can get them in different ride heights. They are designed to work with the Caltrac bars, other springs may create a bind in the suspension. I put this setup on my car last season and the Workmanship was excellent. There is a bunch of adjustability in them, so it may take a while to get the most out of them. Probably the best bolt on leaf spring suspension ever made.
George Mirza D/SA 1236 ‘71 Duster 340 |
03-10-2020, 09:32 PM | #4 |
Liked 167 Times in 81 Posts
Lighter than stock and adjustable ride height with different rear sections
Tim Schmackpfeffer 762 SS |
03-10-2020, 11:17 PM | #5 |
Liked 237 Times in 127 Posts
I have Calvert springs and CalTracs on my 68 Mustang. It was originally street legal and towed a teardrop trailer to the track each weekend. Worked on the track and tolerable on the road. A leaf spring car without Calverts is an odd bird these days. Match them with Caltracs or they will wrap up on you. Get your pinion angle right, too. I messed mine up and tried running shims to correct it. The reduced contact between the centering stud and spring caused it to start to separate and move the right rear wheel. A sharp eyed tech caught it in the waterbox before I cut a tire.
03-11-2020, 08:18 AM | #6 |
Liked 10,049 Times in 2,083 Posts
Its been a long time but the Calvert springs reduced un-sprung weight by about 40#. The rear segment if fairly easy to adjust to change ride height.
03-14-2020, 01:50 PM | #7 |
Liked 19 Times in 11 Posts
can`t beat them
03-15-2020, 08:21 AM | #8 |
Liked 66 Times in 29 Posts
X100
03-15-2020, 12:24 PM | #9 |
Liked 4,805 Times in 1,828 Posts
They are a fine product, no doubt. Also, a great company to deal with.
In my mind though, which runs contrary to a lot of folks here, is do I really need them, and should I put together something of my own, and should I spend the money elsewhere on my combination, which is a _________________?
Real life never quite adds up.... Jay Farrar |
03-15-2020, 01:41 PM | #10 | |
