Old 02-25-2020, 07:05 PM   #1
Marco
Liked 4 Times in 1 Post
Default Super Stock classification
Can someone please explain how the classification process works for super stock. I understand how it works for stock but I understand that its different for super stock
Marco is offline   Reply With Quote
Old 02-26-2020, 01:06 PM   #2
rx dealer
Liked 53 Times in 13 Posts
Default Re: Super Stock classification
Marco, go to classracerinfo.com it has a wealth of information and very helpful to get you in the right class. Luke
rx dealer is offline   Reply With Quote
Old 02-26-2020, 05:26 PM   #3
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Depends on which flavor of SS you are talking about. "Back in the Day" there was Stock and Super Stock,. In these pure forms there isn't any difference in terms of body style, weight and engine (on the outside) between the two. NHRA assigns cars Factors based on shipping weight and HP rating. A 68 Mustang Coup 302 auto has the same factor in both S and SS classes, but there are different breakdowns in each. That car is K/SA or SS/LA natural classes. Where SS classification goes nuts is with all the "New School" classes like GT, Modified Stock and Modified. Here engine swaps and extensive allowed internal machining move the classification to the weight to cubic inch style of math that used to be used for Gasser and Altered classes
For SS, find the car in the NHRA Stock Car Classification Guide and locate the factor number under the ** (double asterisk) and take it to the Rule Book SS section. For other branches of SS, consult the oracle...
Yes, I date back to flag starters...
Dale Shearon
68 Mustang 6394
Old 02-27-2020, 06:05 PM   #4
Marco
What I was referring to is the math portion. Shipping weight minus 250 and then plus 250 or something like that I know how to do it for stock but I'm told its different for super stock
Old 02-27-2020, 06:50 PM   #5
rx dealer
Let say you have a 2016 Camaro and a 427 LS and you want to run in Super Stock.
Say The Camaro will fit FSS/C or C Auto at 7 lb. per h/p.
The 427 is NHRA rated at 470 hp in Factory stock and Factory Super Stock
470 hp X 7lb. = 3290 lb.
NHRA adds 170 lb. for avg. weight of a driver LOL I wish
3290. + 170. = 3460 lb total weight of the Camaro
I hope this helps. Luke
Old 02-27-2020, 07:28 PM   #6
1299
Liked 53 Times in 11 Posts
Traditional Super Stock (SS/xx) is the same as stock natural class up one down one. Where the 250lb come into play is GT/ in GT you could fit 3 class or 5 class if it a low hp combo.
1299 is offline   Reply With Quote
Old 02-28-2020, 11:59 AM   #7
FireSale
FireSale's Avatar
They should put all this info in one place. From the 2020 SS Weight section.
"WEIGHT
All cars will be permitted to run on the class minimum weight, but may be no heavier than the minimum for the next heavier class. Car can move up (lighter) one class or down (heavier) one class. If weight is added, must be properly attached; see BALLAST. In cases where NHRA has placed a performance rating on the engine, use the factored horsepower. Class and classification weight are determined without driver. Once classification weight is calculated, 170 pounds is added for driver to arrive at total weight. All cars are weighed with driver."
BALLAST: 100 LBS MAX.
Note that there are two weights here: Shipping weight from the guide and total (scale) weight at the track. Class is determined without driver. I don't know if class would change if you were at the max weight for a class and adding 170 would put the scale weight one class down.
The goal in adding and subtracting 100 lbs in SS is to let you place the car at a favorable weight. If you are at the bottom of a class, adding weight would let you run at the top of the next class down. A better place to be. When you get into GT and Modified the weight adjustment increases to 250 but you have to determine the shipping weight differently.
Someone should make up a worksheet on classing a Stock or SuperStock car and pin it here.
Dale Shearon
68 Mustang 6394
Old 02-28-2020, 12:33 PM   #8
Marco
Yes!!! It was GT I was referring to I cant quite figure out how to do the math as in what gets added and what gets subtracted
Old 02-28-2020, 04:37 PM   #9
ss3011
ss3011's Avatar
Liked 238 Times in 113 Posts
In GT the most weight you can subtract from the shipping weight is 250 lbs . This may not allow you to get to the bottom of the class . This still allows you to run in that class .
Old 02-28-2020, 05:31 PM   #10
bestephen
I can follow the Stock and super stock classifications its the GT classes that I don't understand. Say I want to run a 352 engine in a 1968 Mustang. How do I determine the class?
bestephen is offline   Reply With Quote
