Old 01-19-2020, 01:58 PM   #1
jmoneyfoot
Liked 9 Times in 5 Posts
Default Amsoil engine oil
Does anyone here run amsoil in their stock/superstocker? What weight? I picked up a sponsor from a small amsoil rep and he wants me to try some. I have never used any amsoil products so any info would be great, thank you
jmoneyfoot is offline   Reply With Quote
Old 01-19-2020, 03:36 PM   #2
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
Default Re: Amzoil engine oil
Originally Posted by jmoneyfoot View Post
Does anyone here run amzoil in their stock/superstocker? What weight? I picked up a sponsor from a small amzoil rep and he wants me to try some. I have never used any amzoil products so any info would be great, thank you
I've been having good luck with the Amsoil 10w-30 synthetic Dominator race oil in my Super Stock 427. Other than a rod bearing issue I had last year, which was not due to the oil I am using, the bearings look perfect every time it's apart. I also use their synthetic ATF and gear lube with good results.
Old 01-19-2020, 06:10 PM   #3
340Cuda
Liked 805 Times in 341 Posts
I have never used it but member "Locomotion" has used it for years and should have a meaningful response when he sees this.
Old 01-19-2020, 06:56 PM   #4
killintime6968
Liked 91 Times in 29 Posts
Smile Re: Amzoil engine oil
The first thing about having Amsoil as a sponsor is making sure you spell their name correctly. LOL . That being said I have used their products for years in my Race quads and sleds. Also have used their assembly lube in engines.
Bruce Cameron
68 Nova 396 E/S
68 Camaro SS/? ex Checkmate Modified
killintime6968 is online now   Reply With Quote
Old 01-19-2020, 07:43 PM   #5
John Dinkel
Liked 265 Times in 69 Posts
Thumbs up Re: Amzoil engine oil
Great oil, I use 10w30 in my stocker
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 01-19-2020, 08:19 PM   #6
Jeff Niceswanger
Liked 1,071 Times in 378 Posts
We have ran it for a long time. Actually had the oil pump pick up break off and made entire 7800 rpm dyno pull with 10 psi pressure and the bearings looked new. Yes, the dyno operator was a bit red faced, but it turned out alright. That's what really sold us on it. We use the 10-30 Dominator, but I know some people with tighter bearing clearances than us run the Dominator 20w all the time. I've been told its slower than most oils on the dyno, but if your looking for protection, its a great choice.
Jeff Niceswanger 3740 SS
