Liked 413 Times in 115 Posts
Kestrel 5100 model. Anyone familiar with this unit. Thermometer appears to be off 8 - 10 degrees. Directions show how to calibrate the barometer and altimeter which I was able to do, however nothing on the temperature. Received this for Christmas from my children. Is this a decent piece ? Thanks for any input/info !
Joe Huestis "Annie's Song" Racing U/SA 2724 Youngsville, NC Last edited by joe huestis; 12-29-2019 at 05:49 PM. |
Liked 19 Times in 12 Posts
I have one and it works great. Are you holding it when checking the temp? You have to hold them a certain way or it can throw the readings off. I hang mine from the underside of my canopy out of direct sunlight.
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ Last edited by black88coupe; 12-30-2019 at 01:12 PM. |
#3 | |
Liked 503 Times in 131 Posts
The 5100 is the new model, if you are finding it is off on the temperature inside your house, I would contact Kestrel. At track, walk around with it a bit to cool it off when in direct sunlight. I change the batteries once a year whether it needs it or not. Great product. My antique dates back to 2010 maybe older? I had to replace the wind meter and lost the wind cover and the soft pounce over the decade, it came with a nice tough pouch too back then. Gives you a lot of useful info, and its small. I just ordered a brand newee 5100 from biondo racing like my original. Will see if I like it as much. I can't see where I wouldn't. Eric
Eric Merryfield 1883 STK |
Thanks Mitch and Eric for your reply. I believe the thermometers I was comparing temperatures with were what was off. My in house thermostat thermometer shows the 5100 dead on. Happy New Year ! 👍
Joe Huestis "Annie's Song" Racing U/SA 2724 Youngsville, NC |
Glad you got it worked out. I hold mine with my hand positioned down low on it as to not throw off the temp sensor.
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
