Old 12-29-2019, 02:49 PM   #1
jmoneyfoot
Liked 9 Times in 5 Posts
Default 2bbl to 4bbl switch
Hey guys I run a dish piston 305 2bbl combo and am switching to a 4bbl, how much can I expect to pick up by just changing the intake and carb? Carb is a dean Oliver quadrajet. Any input is greatly appreciated. Thank you
jmoneyfoot is offline   Reply With Quote
Old 12-29-2019, 03:17 PM   #2
Billy Nees
Default Re: 2bbl to 4bbl switch
Ya know that you've got to change the heads and cam too, right?
If you're just changing the intake and carb to "play" with it, about 7-8 tenths.
Billy Nees 1188 STK, SS
Old 12-29-2019, 04:19 PM   #3
jmoneyfoot
Thanks billy, that's what I was wondering, I know a cam change would be beneficial, I never even considered the heads. Thank you
Old 12-29-2019, 04:33 PM   #4
Billy Nees
Unless you've got a 4V cam in the motor, a cam change would be mandatory. The 2V cam spec is bigger than the 4V cam spec.
Old 12-29-2019, 04:42 PM   #5
jmoneyfoot
The specs are the same, the only difference is the intake valve is bigger in the 4bbl. This is a 78 nova chevy 305 2bbl combo going in a 79 malibu 305 4bbl
Old 12-29-2019, 04:46 PM   #6
Billy Nees
Well OK then.
