Old 12-20-2019, 01:34 PM   #1
4speedracer
Liked 10 Times in 6 Posts
Default rod journal size vs rpm
I know the smaller the better but,what would someone say the highest rpm someone could turn a steel 2.123 sbf rod crankshaft without issue. Thanks
4speedracer is offline   Reply With Quote
Old 12-20-2019, 02:12 PM   #2
Everett Hill
Liked 4 Times in 3 Posts
Default Re: rod journal size vs rpm
all the small block fords are steel which one stock or after market,I have turned mine 10,000 at times mostly 9,000 to 9,500
Everett Hill 2134 STK, SS
Everett Hill is offline   Reply With Quote
Old 12-20-2019, 06:22 PM   #3
340Cuda
Liked 805 Times in 341 Posts
I would say with all the race engines with 1.88, 1.85 and smaller rod journals, turn all the RPM you want.
Old 12-20-2019, 08:53 PM   #4
Ed Wright
Ed Wright's Avatar
Wasn’t the question originally about crank journal diameter versus RPM?
That is about the surface speed of the bearing against the crank. Smaller crank journal diameter reduced the speed of the bearing against the surface of the crank.
Of course, you can usually get by with high surface speeds. Lower speeds improve reliability. “Honda rods” did not make mine any faster, but did reduce bearing wear.
Your results may vary.
Ed Wright 4156 SS/JA
Old 12-21-2019, 06:25 PM   #5
James L Miller
Liked 25 Times in 16 Posts
How much power (or torque) can be run through the small journals? I bought a set of Crower rods with the Quad 4 bearing size. I would think the rear journal would take the most power (torque) through them, but only one cylinder is firing at a time.
Mopar 2 Ya!
